Schematic
Are these resistors in parallel? A question is asked to find the equivalent resistance between X1 and X2; to my knowledge, these resistors are like parallel connections. But the choices are given as:
  • A. 2 Ohms
  • B. 4 Ohms
  • C. 8 Ohms
  • D. 12 Ohms
JYelton
  • 32,302
  • 134
  • 249
Ram
Redraw the circuit so that it makes more sense is the main clue or even colour code all the nodes: -
Count the nodes. How many are there? Does this tell you how the resistors are connected? It should.
is these resistors are in parallel ?
Hmm ...
RedGrittyBrick
  • 14,602
  • 77
-1
The right answer is 2 ohms. The equation can be found at parallel resistors
An instructor put this on test when I was a student, but not multiple choice, just pen and paper and slide rule. This was before calculators were invented.
user3012727
  • A good answer would address the schematic and explain how to redraw it or re-imagine it so that it's obvious how components are connected. Providing the eventual final answer with a link to parallel calculations, I don't think is as helpful. Finally, the anecdotal portion about your past is completely superfluous. – JYelton Feb 22 '14 at 18:06
